What is this hose
dbull65
While washing my truck, I saw this hose hanging on the driver siderear fender well, not sure if it goes to something, or it is a vent tube.
FORZDA 1
Gloucester, VA
Likely a hose from the fuel tank vapor pump. You should look further under there and find the clamp/clip that holds it in place and reattach it. If the hose is damaged (hole) or disconnected, the ECU will set a fault for the evap system.
ChevyChad
My 2017 had the same tube hanging down in that spot. I had to look at a new raptor on the lot to see where it clips back on. I'll get a picture for ya of where it is supposed to go later today when I get home.
ChevyChad
Pic is upside down for some reason, but it goes behind the wheel well.
