MJslasherADMIN
- Joined
- Jan 9, 2015
- Posts
- 556
- Reaction score
- 328
So true. Get used to hearing/reading these three words- "could not duplicate". Ford shortens it to CND to save time- writing CND instead of could not duplicate 100 times a day could save them a few minutes. A few minutes that they can use to write CND on other work orders as well.
Exactly. I have heard and seen this a few times by Ford on various vehicles. I do my research on issues first, or arrive with TSB in hand when possible. I only go see Ford at this point if its going to cost me more than $300 or more out of pocket to fix, or if I need to be towed and cant fix it myself.
My GT500 (2014) was under 3/36 warranty and the inter-cooler pump stopped working 8 months ago. I diagnosed it and bought a pump myself and replaced it in my garage, never even called Ford. I hate taking my stuff to them so that it can get a sun bath, a new dent because it was parked 6 inches away from another car which was also getting a sun bath and eventually a CND report. Then you get back in the car and the launch control is activated, even though you have never used launch control before, and you see that there is rubber in the rear wheel wells, even though you haven't launched or white smoked the tires in the past 6 months and when you took the car there is was clean enough to eat off of.
Or, you will like this one, you go in for an oil change in your 2012 GT500 and your car calls for 6.5 quarts of Motorcraft 5w/50 oil. You pick the car up and drive home. You drive for two months never thinking about it. You pull the dip stick one day and its an inch over the full hash marks. You look at the service order from 2 months ago and they put in 10 quarts. And it was 10 quarts of Mobile 1 50w/50. You call them and they tell you to drive it in, that wont hurt it. I drained it, changed it myself, then took it in to have it bore scoped. Sold the car two months alter because of this event.
Yeah, I dont take my shit to Ford anymore, unless I have to. This is only the beginning of my experiences. When I had a driveline with welding slag broken off inside of it making noise as the drive-line turned I had to go to Ford 3 times and got a CND each time. Eventually I jacked the car up at home, proved what the issue was, video of the issue, took it to Ford, they lifted it, said CND and then I walked back there while it was on the lift and showed them how to test to find it. They did find it and agreed, slag inside of the drive-line. They had to order one, and I had to come back a 4th time for install. I have spent so much time at Ford and driving back and forth and bumming rides from people.
I could go on but I will stop here. This is all in the past 4 years, BTW. Not over the course of a lifetime or anything.
