GEN 1 What all goes into supercharging a gen 1 raptor.
RichKidMay
Sumter, SC
Hello,
Brand new to the forum. I am thinking about putting a gen 4 whipple on my raptor and I was wondering if there is anything else I should upgrade or do prior to the install.
also any suggestions about tunes would be great! I appreciate all the help.
The Car Stereo Company
here, on frf
theres lots of shops here that will tune for you. cant go wrong with the other vendors here.
first thing that comes to my mind when adding a supercharger or turbo, are all the threads i have seen over the years of broken driveshafts. probabpy a good idea to look into an upgrade for that as well.
CoronaRaptor
CANADA
Welcome to the place. You'll need to do something about wheel hop, Suggest Deaver springs in the rear or equivalent.
R
RichKidMay
Sumter, SC
I was thinking about going with some Deavers. One of the guys I work with suggested a traction bar. I feel like that’s overkill.
B E N
Frederick, CO
It kind of depends on your power goals. Oil pump gears wouldn't hurt but there are a lot of supercharged raptors running around without them.
I don't think traction bars are overkill, wheel hop breaks stuff and traction bars will largely prevent it. I have considered building some for my truck and its stock power level. I think driveshafts in this truck break because of the pinion angle change and wheel hop problem, trac bar stops both.
Canuck714
San Antonio TX
Before going into all of the details about what you could or should replace when adding HP, let me ask this first... What are is your intended use for the truck?
Are you looking to play off-road and have good suspension running 37's etc. etc... Or will it be a street driven daily that you want to embarrass mustangs/chargers and diesel trucks in a drag race?
You can build it to do either, it just changes some of the choices you will make.
R
RichKidMay
Sumter, SC
I have suspension upgrades coming in. She’s on 35” at the moment. Just looking to get a little more power under the hood.
Canuck714
San Antonio TX
If you are doing suspension mods for off road, look into Deavers to help with the wheel hop if you ever smash the throttle on the pavement. It wont stop it entirely if you are on aggressive 37 or 35 inch tire, but it helps a ton versus stock leaf. Also, If you plan to run in the dirt more, don't do a traction bar. They just don't let the rear end move enough off road. Great for a street truck though.
I had a tune done by Jim at JDM but I was on TVS (Roush) not a whipple. He still has a ton of tuning experience with either, so I would not hesitate running his tune on a Whipple.
If you are doing the build yourself, take a bit of extra time and pull the front cover while the truck is down. You will have so much of the truck apart to do the install, that you might as well do the oil pump while you are there!! Doing it after is a major pain.
Melling has an upgraded "drop in" oil pump, or you can get the billet gears from multiple places. I did not do the gears as my truck was a factory built blower truck, so I never had it apart. But the thought was always in my head to do it if/when I ever needed to freshen up the engine.
I assume the Whipple kit comes with injectors, gauges etc. so nothing should be needed there.
Transmission likes a converter from Circle D, but stock works fine. The tune is critical here to make it drive well and hold the gears longer.
4:10 gears are fine on 35. Good idea to re-gear on a 37 (4:30 or 4:56), but the extra HP a blower provides, makes the bigger tire work with the stock set up.
The stock exhaust will work with the blower, you will probably want to get less restriction though. Most of the supercharged trucks I have seen work well with the resonator gone and a straight through type muffler
