Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Wheels & Tires Forum [GEN 1]
Want new wheels
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="cascon" data-source="post: 955261" data-attributes="member: 19037"><p>It's nice that you have decided on a wheel but also keep this in mind... "35 x 12.5, R-17" is actually a "Tire" size and not a wheel size. R-17 means that the tire is 17 inches and fits on 17 inch wheels. Both a 35" and a 315 tires will fit a R-17 wheel. However you have to make sure that the tire that you select will work on the wheel that you have selected as all 17" tires will not necessarily fit all 17' wheels. You have to make sure that the wheel width and tire width are compatible. This is especially true when you are running "true" bead lock wheels. The new tires will give you a range of wheel width sizes that the tire can be mounted on, usually 8, 8.5, 9, 9.5, 10, 10.5 or 11 inch wheel widths. Check compatibility BEFORE you buy!!!</p></blockquote><p></p>
[QUOTE="cascon, post: 955261, member: 19037"] It's nice that you have decided on a wheel but also keep this in mind... "35 x 12.5, R-17" is actually a "Tire" size and not a wheel size. R-17 means that the tire is 17 inches and fits on 17 inch wheels. Both a 35" and a 315 tires will fit a R-17 wheel. However you have to make sure that the tire that you select will work on the wheel that you have selected as all 17" tires will not necessarily fit all 17' wheels. You have to make sure that the wheel width and tire width are compatible. This is especially true when you are running "true" bead lock wheels. The new tires will give you a range of wheel width sizes that the tire can be mounted on, usually 8, 8.5, 9, 9.5, 10, 10.5 or 11 inch wheel widths. Check compatibility BEFORE you buy!!! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Gurz38
elusion23
MurderedOutSVT
Bozz
CBreedlove
RamseyF
NickyF25
chi_weezy
lawraptor
HTXaggie
TK85
Tex7432
j8j
Badboy4fun_wa
bne
Willimiza
nealhoney
Jeffreestylz
scottp6188
njhummer18
davidjohns0n
Sozzy12
stevenstommyboy1
Shane361
GCATX
JerseyFR
PlatinumSwap
mperez
shank_guru
ranger22
Rick at FMS
tone228
Winchester30
Admin.RealTruck
IMFletcher
bachfool
MikeTab
PK37
Prormk
jahtrue
DaveInMn
rgz
EastEndAngler
scsponger31
encyphered
GT11
mprice1234
guitar2323
jnall
Dain
... and 31 more.
96,854
60,805
sethkbrown
Forums
Want new wheels
Accept
Learn more…
