MJJ
I had the volant cai installed today and I have a few questions for more informed minds. First off I would like to point out that I was not expecting the noise levels to be so high...hope the neighbours don't kick up a fuss...
1. I currently am not running the ram air scoop. Should I put a cap on the extra hole to prevent it drawing in hot air from under the hood?
2. I am getting some vibrations on the peddle when I hit the gas. Is that normal/expected?
3. When I off-road (mainly soft sand) I envisage I will be putting on a pre-filter. However how would one clean out the filter box of any debris?
4. In terms of the ram air scoop, is the install easy enough? Is it worth ordering or will it just suck in too much sand that is in the air here (Dubai)? It is generally fairly dusty around even in the city (sand and construction dust). However I do like the idea of pulling in real good air.
Thanks in advance for your help.
On a side note the breather hose that was shipped has a kink in it so I think I will be needing to cut a new piece. Is that a common problem? Will I be fine driving with the kink until I can get some new pipe?
