VisionX Utility Light Underhood
mike.s
Well-Known Member
Hey guys, just wanted to share some pictures of my utility light that I just installed. The light is made by VisionX and retails for $99. I bought a strip of aluminum from Home Depot, cut it to size, drilled a few holes and mounted it behind the grill. It is very bright for such a small light.
If the pictures, don't show up, try this link:
https://drive.google.com/folderview?id=0B0wpgqLCVNeLR3daVDg5blh2cHc&usp=sharing
Here's the pictures:
mike.s
mike.s
Well-Known Member
Haha, you can't see the pictures? Hmm...
I uploaded them to Google Drive. I can see them in my browser and my phone.
SilentShooter
Siesta Key, FL
Google drive does not seem to like the embed img option on the forum. The links to the images work fine. I would just change them to links and not embed as IMG and they should be viewable when clicked on
Deleted member 12951
Guest
See em all just fine on my phone. Nice mod. What did you wire it up to?
mike.s
mike.s
Well-Known Member
The battery! :ROFLJest:
Well, temporarily just for the photos. I still need to install a switch somewhere in the engine bay.
---------- Post added at 09:07 PM ---------- Previous post was at 08:43 PM ----------
Just a little more detail about the mounting. The two bolts on the side of the aluminum plate fit into the grooves on the inside of the grill. It's not 100% secure, so I used some gorilla glue to help keep it in place. Hopefully it works. I didn't want to drill any holes through the grill. Keeps it looking clean from the front.
