UPGRADE - 3.0 External Bypass
FOX
El Cajon, CA
Upgrade your Raptor to large FACTORY Series 3.0 Internal Bypass Coil-Over shocks that maximize the entire wheel travel, increases oil capacity, and adds 60% more damping area over the stock FOX SVT shocks. The only Internal Bypass direct replacement kit on the market allows for a plush predictable ride over normal offroad driving conditions but then has the ability to ramp up damping force for extreme use. The front Coil-Overs are also equipped with remote reservoirs with a large -10 hose increasing the shocks cooling capabilities. Utilizing all of the same components form our offroad Trophy Truck race winning shocks with Eibach springs, Teflon lined spherical bearings, proprietary racing oil and Viton seals.
PART# 883-02-047 $2200 Set MSRP
SPECIFICATIONS
Adjustments
Compression bypass adjusters
Rebound bypass adjusters
Free bleed bypass adjuster
Nitrogen pressure
Compression valving
Rebound valving
Body: Smooth-bore, clear coated, zinc plated, honed seamless alloy bodies
Components: Black anodized 6061-T6 billet aluminum
Shaft: 7/8" hard chrome plated stainless steel 17-4 H900
Piston: Race-developed high-flow piston design
Valving: Proprietary deburred valve shims
Seals: Redundant sealing pack system main seal, wiper seal, scraper seal. High temperature Viton seals
Oil: FOX formulated for ultimate performance at variable temperatures
Reservoir: 2.5 Piggyback
Mounting: Direct replacement of stock shock package, Teflon-lined, heat-treated, alloy steel spherical bearings
