Transmission problems
bochy
new york
Hi guys , I have a 2017 ford raptor and I started having some transmission problems , slipping gears , I took it to the dealership and they pull out some codes (p0732) (p07f6) and they said I need a new transmission, i don’t have warranty and the cost is 10k I was thinking on changing the transmission filter maybe low pressure on the transmission because of clogged filter is causing that problem , what you guys think ?
shigman
Cypress, TX
Slipping gears? At full throttle or just 2K rpm regular shifts? How much RPM flair are you having?
thayes614
AK
My 18 w/90k VERY EASY miles and no aftermarket tune just grenaded itself. Popped from 1-3 and locked itself up repeatedly on the 3-1 at 8mph. Was able to force it to shift from 3 directly to 8 by keeping power applied and rolling through the dead spot. Was 150 miles from home in the Mtn's. No choice but to try and make it. The last several months the 4-5 shift seemed harsh (not in Sport or Baja mode) and the downshift from 3-1 was harsh. Pulled the pan and chunks were everywhere. Not going to the dealership, but friend has a shop and ordering a re-man from Ford and he will swap out for less than dealership.
I will be going GooseTune w/TCM going forward to eliminate the possibility of weak line pressure and weirdo shift points. I have heard from many folks that he fixes the factory short comings on the trans tune, as well as the power gains/smooth delivery.
Question: anyone else experience the 2018 failure and upgraded to Goosetune???
ShockerFL
Trinty Florida
I just bought a 2017 it had 78000 on 5 13 24. Drive it to Tx and back home to Florida no issues. Long hours on the hwy. today I took to the Ford dealer I bought from this morning for an oil change and a Trans filed and fluid change. 4 hrs later I’m running 70 on the toll rd and Wam! it slips then slams hard into gear. And seem to lose all power then give some back. So I called taking in the morning to the dealer, I’ll keep you posted on that. in the meantime, I joined the Ford app and noticed the vehicle history. Was there see the attached files? It’s had pior issues Obviously it time to put a new transmission in her. I have a 3 yr 36 k warranty as well. I m not sure what to lead with with the service mgr. 1. You touched it last u broke it. Or 2. Previous history doucment. My thought is they need to sell a totally coved replacement to the warranty company. And throw in the labor for free. Hmm
Any input is appreciated???
