Transfer case / drive line slop
stewwalker
Kingsville/Houston
Just got my truck back from the dealer after I brought it to them for drive line play. I noticed play in 1st and 2nd gear when driving in traffic. They replaced a shift solenoid said it was fixed. Crawled under the truck this afternoon and it looks like the issue is in the transfer case.
Here is a video of what I found. https://m.youtube.com/watch?v=NML3AGcjbxk&feature=youtu.be
I have little to no experience with transfer cases. Can anyone verify if the play is within spec and the ratcheting sound is normal?
Pyro3601
Lethbridge Alberta Canada
I know the gm's with the 10speeds (same trans shared with the new raptors) have a tonne of play in the drive line. We have more then one tsb/bulletin regarding the complaint. For the gm trucks. It's worst first "garage" shift of the day. Especially into reverse. And then 1-2 shifts and hard multi gear down shifts if can be experienced. Especially in colder ambient temps.
stewwalker
stewwalker
Kingsville/Houston
Interesting. I’d think the 10 speed trans would have higher tollerences given the fact that it shifts more often, thus would cause more wear in theory. That is if the clunk in the 10 speed is being caused by play in the gear mesh.
Raptized
Raptorida
Damn man, you live on a Nascar track. If that is under warranty, I'd take that dude back in.
BlueScapegoat
MN
A little off topic here but I just bought my first Raptor, a '13.
Can anybody tell me whether the transfer case is gear or chain driven, and what the low ratio is?
Or maybe point me in the direction to somewhere I can find all the truck's specs in one place?
Transmission, transfer case, axle models, ratios, etc.
Raptized
Raptorida
Performance Specs
Engine
Engine Order Code 996
SAE Net Torque @ RPM 434 @ 4500
Fuel System Electronic Fuel Injection
Engine Type Gas V8
Engine Oil Cooler NA
SAE Net Horsepower @ RPM 411 @ 5500
Displacement 6.2L/379
Transmission
Drivetrain Four-Wheel Drive
First Gear Ratio :)1) 4.17
Sixth Gear Ratio :)1) 0.69
Transfer Case Model N/A
Trans Description Cont. Automatic
Fourth Gear Ratio :)1) 1.14
Trans Power Take Off NA
Transfer Case Power Take Off NA
Trans Order Code 446
Second Gear Ratio :)1) 2.34
Reverse Ratio :)1) 3.40
Transfer Case Gear Ratio :)1), High 1.00
Trans Description Cont. Again NA
Fifth Gear Ratio :)1) 0.86
Trans PTO Access NA
Trans Type 6
Third Gear Ratio :)1) 1.52
Clutch Size (in) NA
Transfer Case Gear Ratio :)1), Low 2.64
Brakes
Brake Type Pwr
Front Brake Rotor Diam x Thickness (in) 13.78 x 0.55
Disc - Front (Yes or ) Yes
Rear Drum Diam x Width (in) NA
Brake ABS System 4-Wheel
Rear Brake Rotor Diam x Thickness (in) 13.7 x 0.413
Disc - Rear (Yes or ) Yes
Brake ABS System (Second Line) NA
Drum - Rear (Yes or ) NA
Steering
Steering Type Pwr Rack & Pinion
Turning Diameter - Curb to Curb (ft) 47.0
Steering Ratio :)1), On Center 17.0
Turning Diameter - Wall to Wall (ft) N/A
Suspension
Suspension Type - Front Double-Wishbone
Axle Type - Rear Semi-Float Beam
Shock Absorber Diameter - Front (mm) 46.99
Spring Capacity - Rear (lbs) 3700
Axle Ratio :)1) - Front 4.10
Stabilizer Bar Diameter - Rear (in) NA
Suspension Type - Rear Live Axle
Axle Capacity - Front (lbs) 4000
Shock Absorber Diameter - Rear (mm) 46.99
Axle Type - Front Long-Spindle
Axle Ratio :)1) - Rear 4.10
Spring Capacity - Front (lbs) 4000
Axle Capacity - Rear (lbs) 3700
Stabilizer Bar Diameter - Front (in) 1.08
