Trailer Sway
BenjiG
South MS
Has anyone tuned off the trailer sway control while towing and noticed less sway ? Trying to figure out why I’m having trailer sway on 2024 raptor 35 package . Using same setup that I had on my 2020 tundra Trd pro and the truck and trailer are fairly level and my tongue weight seems to be correct . Using e2 fast away 10000 lb WDH. Towing 6000 lb travel trailer .
Starts to sway after 50 miles an hour . Otherwise tows great . I read some comments that the trailer sway control counter acts the WDH. Not sure if I trust that .
Ox3721
Arizona
My understanding is that the system is designed for use when using hitches without any inherent sway control. I use an Andersen WDH on a 5k lbs TT and always turn off the sway control. 2021 37.
Ox3721
Arizona
Found this for the Andersen manual. Not apples to apples for your situation, but the physics are pretty much the same so the same should apply.
