What these guys above said. If it’s a one time trip, get a trailer and go that route. Blue box base plate will cost you $425 or so. The wiring kit to connect your lights is $85. The air force one braking system is $900 for car side air, $1200 for the full system if your coach isn’t already set up for it. There are other braking systems like rvibrake3 or blue is patriot. Then you will need a 10k tow bar plus related cables, etc, approx $750 new. Add in installation and it adds up. I did all the installation myself and was probably close to 5hrs cumulative time?
To answer others questions: no more wear and tear than every day driving. I rotate my tires 5k miles regardless of towing or driving. Steering works fine. The settings in the menu keep the steering wheel unlocked and disconnects the t-case so it rolls free. It displays a message saying the truck is in neutral tow. Very easy to set up. Literally takes me 3minutes to connect everything and go.
