Top 4 Most Common A/T and M/T Off-Road Tires at CARiD
carid
Cranbury, NJ
Every new, adventurous journey on the muddy terrain and the beaten path starts from the moment when your tires touch the ground. It depends on them whether this adventure will be exciting, or turn into a catastrophe. Reliable All-Terrain and Mud-Terrain off-road tires provide superior traction and optimal handling thanks to the open tread design.
It's not hard to get lost in the variety of options available on the market today, so we decided to create the list of the most common off-road tires available at CARiD.
#1 BFG KO2 285 70R17 Tires
https://www.carid.com/bfgoodrich-tires/all-terrain-t-a-ko2-lt285-70r17-818237674.html
Features:
- Split and bruise resistant sidewall rubber, derived from BFGoodrich's race proven Baja T/A®KR2 tire
- Increased rubber thickness, extending down the sidewall to protect more of the critical sidewall failure zone
- Protruding sidewall rubber blocks provide increased mud, snow, and rock traction, especially in aired-down driving situations
- Provide increased tread block stability, for more even wear over the long haul
#2 Cooper Discoverer AT
https://www.carid.com/cooper-tires/discoverer-a-t3-17749543.html
Features:
- Saw-tooth grooves and serrated steps create biting edges for traction and dislodge stones and debris
- The tire is engineered to provide outstanding performance in both on and off-road driving applications
- Compounds are formulated with the highest content of chemically-coupled silica for maximum wet traction
- High tensile construction provides maximum strength and more protection with a higher load capacity
#3 Terra Grappler G2
https://www.carid.com/nitto-tires/terra-grappler-g2-38834197.html
Features:
- Coupling joints, which connect the outer most tread blocks to the center blocks, to increase the block edge rigidity
- Full Depth Sipes
- The staggered shoulder lugs provide additional biting edges in off-road conditions
- The computer analyzed tread block arrangement reduces tire noise normally heard at highway driving speeds
#4 Goodyear Wrangler Tires
https://www.carid.com/goodyear-tires/wrangler-duratrac-487420.html
Features:
- TractiveGroove Technology™ offers enhanced traction in deep mud and snow
- Highly angled center tread blocks enhance traction and lateral stability while reducing road noise
- Self-cleaning shoulder blocks clear the tread of debris for enhanced dirt, gravel, and mud traction
- Rim protector helps protect wheels from accidental curb damage​
Members online
95,320
58,843
brucebarson
Latest posts
