GEN 2 Top 15 Tonneau Covers - which do you have?
Which Tonneau do you have?
  • Total voters
    444
Toadster
Folsom, CA
15 Best Tonneau Cover for F150 | HonestInsider.com
#1 - BakFlip G2
Features a new “living hinge” set of water sealants
This cover is the second generation of BakFlip tonneaus. It provides a wide range of benefits, including a tough set of UV protective laminate panels intended to take a lot of heat. The panels are relatively simple to install, yet fold out easily. In addition, this cover features a new “living hinge” set of water sealants.
BEST DEAL - AMAZON.COM
#2 - Angry Elephant Hard Cover
Premium tri-fold cover features with no premium in cost
This hard tri-fold cover features fiberglass reinforced polymer surfaced panels. It removes in less than 3 minutes. And is ding, dent, and UV resistant.
#3 - TruXedo Titanium Hard Rolling
Slat caps keep the cover from overheating
This cover is built with integrated slat caps intended to keep the cover from overheating, in addition to a UV resistant vinyl coating with a leather grain. With a secure locking system for the tailgate, this cover comes with a 3 year warranty.
#4 - Retrax Pro MX
Features sealed ball bearing roller design
Built with industrial strength aluminium, this tonneau is focused on a low profile design that is capable of being opened and closed with one hand. With a sealed ball bearing roller design, it does not need pull straps.
#5 - BakFlip VP
Handles a wide range of difficult weather climates
Intended to be installed on a wide range of truck models, this cover is built with aircraft grade aluminium and covered in a weather resistant vinyl coating. It's constructed to be resistant to scratches and dings, and is intended to handle a wide range of difficult weather climates. Especially in rain, snow and intense sun.
BEST DEAL - TONNEAUCOVERED.COM
#6 - BAK Revolver X2
Designed for speed
This tonneau is built with a specialized latching spring system intended to keep the tonneau securely on the truck. With its quality materials, it does not sag or hinder itself when the truck is driven at high speeds or over rough terrain. Additionally, it can improve a truck's mileage when used.
#7 - Roll-N-Lock LG111M
Durable value for the money
This tonneau system is intended to be a durable value for the money. With a vinyl sheet that is constructed over aluminium slats, this cover is a manual open system. It comes with a handful of preset positions intended to make opening it even easier.
#8 - Smittybilt Smart Cover
Features unique fulcrum hinges
This advanced tonneau is notable for its fulcrum system of hinges. These make opening and closing the cover a breeze. With a speed lock system intended to make installation and removal easy. It also comes with a set of nylon reinforced plastic buckles.
#9 - BakFlip F1
Heavy duty latches
Featuring heavy duty latches encased in carefully molded plastics, this tonneau is intended to take a beating. Additionally, the flush hinge minimizes the ice and water build up on the cover of the truck and is designed with high speed usage in mind.
#10 - Rugged Liner E3-F5509
Made for 2009 to 2014 F150 truck beds
Intended to fit in 2009 to 2014 F150 truck beds, this tonneau features an advanced quick clamp system to open and close in less than three minutes. It boasts an easy to assemble set up that requires no tools. It features a tailgate lock intended to improve the truck's fuel efficiency and security.
#11 - Tonno Pro 42-305
Tough frame bolstered by 6063 aluminium
Constructed of 24.5 grade vinyl polyester, the fabric of this tonneau is intended to take a lot of abuse. The frame is tough. It's bolstered by a 6063 aluminium frame. Finally, the tonneau features a powerful rubber seal to keep moisture out.
#12 - MaxMate Trifold Tonneau
Built to deal with extremely wet conditions
This moderately priced tonneau has a set of patented clamps intended to make its installation easy and painless. Coated in a vinyl material with aluminium powder, this was built to deal with extremely wet conditions and comes with a 10 year warranty.
#13 - TruXedo 297701 TruXport
Adds aerodynamic contours to your truck
This tonneau is intended to look good and be functional at the same time. Featuring a design that adds aerodynamic contours to your truck for up to a 10 percent boost in gas mileage. It clamps on easily, requiring no drilling and has a dual latch system for quick release.
#14 - Bestop 19111-01
Features an adjustable tensioning system
This is a rolling model of tonneau, intended to be rolled out quickly and easily. With weather resistant fabric and aluminium rails, this tonneau is sure to last. Additionally, it features an adjustable tensioning system to keep the fabric flat.
#15 - Lund 95072 Genesis
Built specifically for 5 feet 5 inch truck beds
This tonneau cover is built specifically for 5 feet 5 inch truck beds, a common size of F150. It features a trifold opening, intended to allow users to access their truck bed's contents quickly. This cover is designed to last quite awhile with it's tear resistant fabric.
do you agree? which one do you have? or "other" ?
StrikerHawk
Huntsville AL
Bak Industries RollBak
Looks good and has held up well over the past 6 years, though I'm choosing not to put the same one on the new Raptor.
The canister that the cover rolls up into does eat up a decent amount of bed volume, and with only a 5.5 foot bed to begin with, loosing an additional 9 inches or so has been a problem in the past.
The system is very water resistant, but despite the design including drain tubes, the canister still fills up with water as the cover ages and the drain tube inlets become clogged with debris, and it will slosh out into the bed or finally dribble out of the drain tubs as you drive.
Just looking for something different to try with the Raptor.
FordFanStan
It doesn't appear any of those are flush mounted, they all stickup above the bedrails some. Is that correct?
StrikerHawk
Huntsville AL
waterproof?
Not waterproof, none of them are, but the RollBak is pretty water tight as they go. The biggest single problem as mentioned above, as that once the drain tubes plug, and they will after a few years, the canister holds water, then when you retrace the cover, put all your stuff in the bed, and then pull the cover out, it's literally dripping wet right onto all of the stuff you'd like to keep dry, thus my decision to try a true tri-fold on the new truck.
