willwwright
I have eibach springs up front, is it necessary to get an aftermarket upper arm? Mild off-roading a few times a year, mostly just chasing around baja and local socal deserts.
Upper control arm is weak from the factory. If you are out often it would be worth the swap.
Oh damn!My friend works for Alphaequipt, and he got stuck out in Johnson Valley in their shop Raptor when the stock UCA ball joint completely sheared off. Stock truck with wheels, tires, and eibachs. That’s the only one I’ve ever heard of personally. I think it really depends how hard you run off road.
