Titan7 T-AK1 on GEN3
Raptor911
Ashburn, VA
I had these on my 2019 (1st image below ... more pics here >> https://www.fordraptorforum.com/thr...tracs-on-performance-blue.76183/#post-1482740). Some specs
- 17x8.5 at -1 offset. They are forged and hub-centric
- I weighed the GEN3 base wheels and they are as follows: 93.35, 93.15, 93.7 and 93.5
- Titan7 wheels with Duratracs are as follows: - Titan7 T-AK1 w/Duratracs: 83 (3.25oz to balance), 84.2 (1.5oz), 84.2 (4oz) and 84.35 (2.75oz) pounds
- these do NOT come with center caps.
- 2019 TMPS work on 2021s.
- on my GEN2 they rub at full lock. There is NO rubbing whatsover on the GEN3. Ford def made the GEN3 wheel wells bigger as these wheels at -1 offset is NOT any where close to touching anything.
titan2-jpg.144040
redwolf719
Minnesota
That is an awesome weight reduction!!! Lost about 40lbs of rotating mass, can't beat that.
I have alphaequipt delta 17x8.5 et25 wheels that weigh in at 28lbs. I'm mounting 315/70R17 Goodyear Wrangler Territory MT tires on them on Friday. Goodyear claims the tires are 54lbs each, which is about 10lbs lighter than any other tires this size. Factory K02 is 65lbs. I found lighter wheels such as the Titans you have, but wanted a near factory offset so these alphaequipt were the best option for me. I'm specifically targeting the lightest setup near factory size and offset.
Token
Fayetteville, AR
Really wanting to run the black Titans on my OW 37 if it ever comes in. Would be dropping 15+ lbs/corner over the stock 37 BLs with the stock tires. My only hang up is the lack of center caps - Titan said at one time they were developing center caps for them but that's been over a year ago. They've also claimed they are working on a T-AK2 so impatiently waiting to see that wheel as well. Any noticeable feel in the butt dyno dropping that much rotating mass?
HOLESHOT
Mid East Coast
Stock Gen 3 tire and rim 99lbs.
Goodyear Territory M/T 56 lbs and a aftermarket rim of 25lbs = 81lbs
Total unsprung weight 17 lbs savings at each hub. This is major!
This could reflect in better mpg and at least 1/2 sec quicker quarter. If stock is 13.9 on 35s
Rims and tires could bring it to 13.4 and with a Cobb stage 2 tune (when available) guessing 60 - 80hp and 100 -120tq would put the truck about 12.8 in the quarter. BAM - TRX territory.
TRX can only pull at 12.3 - 12.5 with race launch on a street if all conditions are perfect. With out race launch 12.7 - 12.8.
These are ruff # lol.
Then add driver error.
Raptor911
Raptor911
Ashburn, VA
In my last communication with Titan7, this was their reply:
We have a few bronco fitments In the works.
T-AK1 - still no center caps as these were already engineered and produced with tooling
T-AK2 - We are engineering the wheels to fit center caps but no official release date as we’ve been experiencing a lot of production delays with the current Covid climate
BTW .. I have a 2022 bronco coming soon.
StuPidaso
BFE
titan2-jpg.144040
How close in person do those wheels match the new GEN3 Fenders? They look very close but would like your opinion. Thanks
