Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Engine Discussion and Performance Mods
Thought I was going to have a heart attack!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Gunner75" data-source="post: 315394" data-attributes="member: 6623"><p>Spring clamps are not a one use item. Many questions come up with the OP. Wrong clamp???? Maybe. Turned wrenches for several years and used spring clamps over and over. </p><p>I will say that with any air lock, you will receive a "burst" when it passes and spring clamps may not hold, but with that said, std hose clamps can be over tightened and equally weak as this or not tight enough and similar results. '</p><p>Maybe they used lube or "grease" to aid in assembly????</p><p></p><p>If a spring clamp is over or slightly on the barb, I could see one popping. Just my .02</p></blockquote><p></p>
[QUOTE="Gunner75, post: 315394, member: 6623"] Spring clamps are not a one use item. Many questions come up with the OP. Wrong clamp???? Maybe. Turned wrenches for several years and used spring clamps over and over. I will say that with any air lock, you will receive a "burst" when it passes and spring clamps may not hold, but with that said, std hose clamps can be over tightened and equally weak as this or not tight enough and similar results. ' Maybe they used lube or "grease" to aid in assembly???? If a spring clamp is over or slightly on the barb, I could see one popping. Just my .02 [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
snt505
dsg2003mach1
jwineco5
Chewie
JohnyPython
CecilK12
Douglasj76
Venti Raptor
REX111
ToadSmasher2K1
FJohnny
Raptor Vet
RaceUV
someday
SterlingE55
Mrpocketpossum
Rap19
Badboy4fun_wa
scottp6188
WMRaptor
md270raptor
wyomingraptor
2025 Raptor
DoubleE
Idaho
KRH
GordoJay
EastEndAngler
mprice1234
Raptorman19
drtibrd
SRQ_Driver
spring
cr23raptor1983
KPT
Loosescrews1
Trail_Rider
RoNiN Raptor
blcws6
Rickmeister
SeasickLI
The Car Stereo Company
sonicraptor
96,856
60,809
hazardsyd
Forums
Accept
Learn more…
