Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Exterior Forum [GEN 2]
Tailgate Applique (not what you think!)
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="RustyNutz" data-source="post: 1616327" data-attributes="member: 41042"><p>I will add, when I took mine off many of the clips are accessible from the inside of the disassembled tailgate. I think i used a soft plastic wedge to maintain outward pressure, and worked from the inside-center out. I kept my gate mounted to the truck for stability. Remove topcap, inside, step assy, then go after clips. I believe there is also some double-sided tape in areas.</p><p></p><p>For ones that are only accessible from the face, I like porters idea of a slimjim. I always use an extra long 90 degree pick to depress the tabs, but you have to use extreme caution to not slip and scratch something.</p></blockquote><p></p>
[QUOTE="RustyNutz, post: 1616327, member: 41042"] I will add, when I took mine off many of the clips are accessible from the inside of the disassembled tailgate. I think i used a soft plastic wedge to maintain outward pressure, and worked from the inside-center out. I kept my gate mounted to the truck for stability. Remove topcap, inside, step assy, then go after clips. I believe there is also some double-sided tape in areas. For ones that are only accessible from the face, I like porters idea of a slimjim. I always use an extra long 90 degree pick to depress the tabs, but you have to use extreme caution to not slip and scratch something. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Griffin
Administrator
Members online
pcs
ilikebmxbikes
HighwaySentinel
Oldfart
Rob O
steved57
arquatro
Edwin
Johnnydonuts
MCD_Raptor
SeasickLI
firstwatch
snt505
dsg2003mach1
dfranks
JB426
Raptor2018
SVT-SourCream
Nathan Reed
GAMike
vintagemario88
zahmadi04
raptorsub
taquitos
elking
Andrewalker7
77Raptor
Dudebrodude
atroyste
Griffin
scg149
Topher1136
Sozzy12
Dan H
NickyF25
brettmess24
Booth9999
tone228
raptortrav001
Raptor812
Keith88
Bozz
FoShizzle
PK37
an48customs
JeepSRT8
DDBama
TomDirt
smgilles
mprice1234
... and 28 more.
96,592
60,559
pnw_raptor
Forums
Accept
Learn more…
