Sync3 Info System with major bugs—what to do?
ParkCity06
Utah
My entertainment center has suddenly become very buggy. If CarPlay is ever recogized via USB, i have to go through a series of connection prompts—5-6 of them, before car play works. And every time I start the call.
I also get times where the screen stays black, and plays the FM Channel last listened to, and where i have no control to change the change or even turn off the audio—so i just turn down the volume.
Finally, sometimes the rear view camera stays on even when in drive.
I have started with apple to learn if it was an iPhone problem, but i dont’ have this issue of connectivity with my daughters 2020 F-150.
Anyone else have gone through this, and what was the remedy? Will make an appointment with Ford, but thought I would ask the forum first.
Thanks all.
deadeye99
South and Centra FL
Mine was acting up about a year ago after a sync update that didn't install properly. I went on Fords website and downloaded the newest sync update, they use your vin#, and I reset sync and installed the update through the usb. No problems since and saved a trip to the dealer. Hope this helps. Bob
thatJeepguy
GA
Yes I did the same download on to thumb drive and follow the directions.
Most CarPlay issues are caused by the cord; if it is worn, damaged, or cheap aftermarket, it will not work consistently and will have functionality issues.
The majority of infotainment system concerns are device and/or app related. It’s best to do a Master Reset and update to the latest version of Sync.
P
ParkCity06
Utah
Thanks all-
i use new cords, but i shouldn’t have to go through the setup prompts for car play every time i start the truck.
i will go online to learn how to do the master reset. Hopefully it will solve the camera issue too.
Thanks again.
icecoldak
Thanks all.
This is what's going on--Your APIM has a memory full issue with the latest SYNC 3.4 Build 22251!
SYNC 3.4 issue
tlrmade
Nashville
this all has to do with the latest update from Ford. Mine was fine until that update via usb.
Doing the reset helps get it back to normal.
My issues
Touch screen doesnt work sometimes
Black Screen....this is 9/10 times it messes up.
Back up camera stays on entire time....this can make me motion sick haha
tlrmade
Nashville
Thanks all.
yes this happens to me 9/10 times I turn my truck on.
Morgan
San Antonio
I'm not affiliated with these guys, but I did receive one of their early release CANopener products several years ago. Great product and excellent service/ communication (back then).
If I were having this issue, I would call and ask for advice/support.
debauch
Earth
There must have been an update a few days ago. Mine has been slow, buggy, and keeps resetting. It just started a few days ago.
95,462
59,070
Asqrd
