Stock Tires Rubbing
bcjohnson22
Northwest Missouri
Does anyone else have issues with the stock tires and wheels rubbing? It's not bad, but it bothers me that it happens when everything is stock besides being on mid perch.. Which you would think should eliminate any rubbing at all with that setup. It usually just happens when I am backing up and cut it hard either direction. Just seems odd to me that it happens at all.
apeezie289
The front of the inner fenders tend to bend in at highway speeds.
Backing up and turning after highway driving the tire grabs the front edge of the liner and makes a rubbing noise.
YES!
Mine does the same exact thing, only after driving on long road trips!
Thanks for this, I thought I had a serious problem.
AP
MTF
Celebration, Florida
I just take the small squared part that hangs down of the front inner liner and bend it up towards the front and push the whole piece to the front with my fist.
I did it a couple of times now really good and haven't touch it in months.
If it sags down again, I've been thinking about making a hole and attach a spring to hold it up away from the tire.
