98rangerdave
Hey forum, I installed a set of -12mm offset wheels about a month ago and since then I’ve heard a spring popping sound coming from the drivers side. Only happens at low speed, like backing out of a driveway or turning share around a turn. Never from the passenger side. I though maybe something was loose, but checked lower control arm frame bolts, upper control arm bolts and the uniball bolt (Camburg upper arms). It sounds like the spring is getting bound somewhere but nothing is showing signs of rubbing. Any ideas?
2012 f150 with Gen 1 raptor swap. All OEM parts munis the Camburg upper arm.
