spare tool kit location
velocir matt
alright fellow raptorians, i understand i am a little slow but i can't find my spare tool kit. are there screws or something behind the seats (have the supercab) but my carpet doesn't come up? help please.
thanks
Dane
Littleton, CO
If it's the same as my SuperCrew, fold up the rear driver side seat. Under that there is a little cubby - good for storing small stuff. That cubby actually pulls out. Now, further towards the passenger side there are two knobs you can unscrew with your hand. These are holding the kit in. Once you remove those, you should be able to pull the kit out via a red strap that should be visible. I believe the Jack base will actually be on the far right of the cubby - it's held in pretty tight.
Again, this is assuming it's the same as the Screw.
Also, there's always the manual.
