SCMike
***SOLVED***
2019 SuprCrew
I installed Eibachs a few weeks back. I wanted to give it a little time before making a judgement, but my Raptor is not the same truck as it was stock. In my research, most if not all are saying the ride was a little firmer, but overall an improvement over stock. This is not the case for me, as i now feel ever single bump in the road, im getting bump steer pretty badly, and the expansion joints in the highway are unbearable. My 2017 F250 i just sold rode better non the highway with 70# of pressure in the tires. As for my wheel/tire set up, I have 17 inch Venomrex 602s with 35x12.5 Nitto Ridge Grapplers filled to 37 PSI. One thing i did notice was I now have some negative camber. I dont have the print out of the alignment, so i cant check to see if i'm within spec or not. Would negative camber play into the ride quality? The offroad show where i got my springs installed also did an alignment and are a reputable shop in the area. They did the level on my F250 and it was perfect.
Has anyone else experienced similar results with their Eibach install. Any suggestions on things i could do to fix my ride? I want that buttery soft Raptor ride back!
I took this pic to show the negative camber. Its kinds hard to tell in the photo, but its there:
Here is a pic of the truck before the springs are installed (just because this thread needs pics
![IMG_2897.jpeg IMG_2897.jpeg](https://www.fordraptorforum.com/data/attachments/119/119746-988ce66e584fac90178610617d82c724.jpg)
![IMG_2950.jpeg IMG_2950.jpeg](https://www.fordraptorforum.com/data/attachments/119/119747-f80d4577fba828d140a920d77665e231.jpg)
2019 SuprCrew
![119747-f80d4577fba828d140a920d77665e231.jpg](https://www.fordraptorforum.com/data/attachments/119/119747-f80d4577fba828d140a920d77665e231.jpg)
![119746-988ce66e584fac90178610617d82c724.jpg](https://www.fordraptorforum.com/data/attachments/119/119746-988ce66e584fac90178610617d82c724.jpg)
