did you make that plywood piece?
yes I made it. Marine grade plywood. Oil based stain. Super glides. Lifted up with a spacer under the track so you can get the ramp out. Cut out Handle in the middle. It’s heavy.
does the plywood extend beyond the length of the bed + tailgate being down?
no. Cut to length. Aluminum 90 bits up against the tailgate. I made some wood spacers that I put in front of and beside the wheel wells. It holds the deck in place, side to side.
what exact model supports do you have off of that site? Very interesting. Never seen those before.
I believe it was the same one as the regular f150. But it would be good to ask them. To be honest I only use them from time to time as the cables have been fine so far.
have you left the sled in with that setup for an extended period of time? Any damage or bends in your tailgate setup?
no damage. I take out the sled most of the time but it has sat for a few days when I’ve been lazy. The key is good thick plywood to save the tailgate.
thanks to all!
