Small vapor leak smoke test
Beenjammin
Auburn, AL
Well I got the check engine light on my 2017 gen 2 and scanned it and it’s the small vapor leak message
I did the gas cap funnel trick, changed the evap purge valve and no dice. I put a smoke test in it yesterday and the smoke was coming out from under the body on the passenger side and also from behind the engine under the frame?
It’s like some seal or hose is just loose? Or maybe some valve is stuck open? I took some videos to show where it was coming it. I’ll try and post some pics
