Single 10" or 12" sub encosure
csirnak
Looking for a sub enclosure that replaces the stock sony sub or SLIGHTLY larger. I don't want to lose the storage that's available under 2 seats, just the single seat.
Stang
I just put in a JL 8" microsub and am very happy with it. I'm pushing around 200W to it from a 5 channel amp and the bass hits hard enough that you feel it in your chest but not a block away.
The box is pretty much the exact dimensions of the area under the passenger side rear seat. They also have a 10" box that might fit sticking out just a little. If you read the reviews on the 8" everyone pretty much says it sounds bigger than it is. I got it from Crutchfield for less than on the JL site.
http://www.jlaudio.com/cp108lg-w3v3-car-audio-microsub-subwoofer-systems-93133
C
csirnak
This is a great suggestion! I wasn't even aware of the microboxes from JL. So the 8" fits perfectly? Shame the 10" is a little too big. But still, that's 8" from JL is probably 1000X better than the stock sub.
Desert Storm
Charleston, SC
CP108LG-W3v3 - Car Audio - Subwoofer Systems - MicroSub
What are your exact amp specs... I'm thinking about copying your setup.
---------- Post added at 08:50 PM ---------- Previous post was at 08:48 PM ----------
if you want something a bit more custom and a bit more bass, we have a 10" setup that works great and bolts into oem mounting locations
Could you send me the details for this setup.. I'm very interested. Thanks.
Stang
Soundtream RUB5.800
Soundstream Rubicon Series 5-Channel Class A/B Car Amplifier
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 200 watts x 1 chan.
2 ohms: 115 watts x 4 chan. + 340 watts x 1 chan.
Bridged, 4 ohms: 230 watts x 2 chan.
MOSFET power supply
Platinum 4 AWG power block
LED protection indicator will be illuminated when the amp has gone into a self preservation mode
Tri-mode capable
IDI intelligent distress indicator for thermal, short, & impedance protection
Infinitely variable crossovers w/ multipliers (High/Band/Low)
5 channel operation
Turn on/off delay
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Selectable high-pass filter (15-225 Hz or 255-3800 Hz)
Selectable low-pass filter (50-800 Hz or 250-4000 Hz)
Subsonic Filter (35 Hz)
Bass Boost: 0-12 dB @ 50 Hz
Damping factor: >250
Signal-to-noise ratio: 105 dB
THD (Total harmonic distortion): 0.015%
Frequency response: 10-35,000 Hz
Dimensions: 19-11/16"L x 8"W x 2"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
1-year Manufacturer's warranty
