- Joined
- Jan 19, 2015
- Posts
- 304
- Reaction score
- 415
Not sure if anyone else has had this problem, but when the Road Armor Stealth bumper is installed, the tow hooks will have a clearance issue with the bumper. We shimmed the hooks down with about 5 washers that are the correct diameter for the mounting bolts. The thread of the bolt goes all the way through the frame section with several threads protruding through the top side, so there is plenty of bolt "bite". Anyone see an issue with this solution in terms of strength/safety in the event that the tow hooks need to actually be used?
