Rubbing of the rear tires on the bed
IL-raptor-sca
Woodridge, IL
Does anyone have a rubbing issues with the rear tires rubbing on the wheel well and side flares. I have a 2019 Gen2 with a 4" Fabtech lift and run 37" tires.
TXRaptor
Sounds like you have a wheel offset issue. I am running 37” Toyo RTs with Deaver +3s and I have no rubbing on the rear wheel well or flares on mine. My wheels are 17x8.5” with +6mm offset. Factory wheels are 17x8.5 with a +34mm offset.
Out of curiosity, how did they lift the rear of your truck? Bigger blocks or did they stack blocks? Most Raptor owners do a bit of research and Do NOT use traditional lifts, like Fabtech to avoid issues when off-roading.
