RPG 3" Bump Stop Extensions
TXRaptor
Does anyone have a set of RPG 3" bump stop extensions for sale? I am going to pickup a load of furniture this weekend and I am looking for an easy way to reduce sag. I called RPG and they do not have any in stock, so I thought I would check to see if any other vendors might have a set in stock.
Reply here or send me a PM.
In case anyone is curious, I bought the Roadmaster Active Suspension last week for the same purpose. Since I have standard Deaver +3s, they will not work due to the arch of the leaf pack. I installed them on Saturday and the driver side popped off over a very mild bump during my initial test drive. Roadmaster was very good about giving me a full refund since they were not sure they were going to work in the first place.
I am happy to listen to other ideas for temporary leaf spring sag relief.
TXRaptor
TXRaptor
i'd just call @TEXAS MOTORWORX and see if they have any. If not, they could most likely help find them.
Great idea! I called and they do not show any in stock. He is going to look around and call me back if he finds a set.
EDIT: Hunter called me back and he said he was not able to locate a set in their inventory. I have to admit they give great service for such a low-cost item ($100) considering I did not use them for my initial build. :cool:
zombiekiller
OG BooBooRunner
New Orleans
Polyperformamce might be a other good place to try, or off road warehouse . Tmx is always my first choice.
TEXAS MOTORWORX
Dallas, TX
Hunter brought this up in our morning meeting. I found these. They appear to be 1" taller than stock. I think this is what we used way back in the day when customers would want to tow with their Gen1. You are welcome to them if you want them.
-Jason
TXRaptor
TXRaptor
-Jason
Thanks for the offer! I am looking for the 3" extensions because I have 4" of space between the bottom of my bump stop and the plate below. I am fine with an inch of sag, but 3" of sag will put me nose high by a lot while towing!
RPG
Orange County
We have them in stock and can ship them today.
-Jason
A while ago, Fox changed the diameter of these... The Fox airbumps with white Delrin have a smaller Diameter... The Fox airbumps with Black delrin have the same size as your pieces.
R
Rick@FreedomMotorsports
Guest
Well I was going to say we have a set but RPG already jumped in when I inquiried about it. Thanks Andrew.
RPG actually makes these with a machinist
TXRaptor
TXRaptor
I just placed my order for a set of the 3" extensions and the air control valve to fill up my bump stops.
Thanks Andrew!
TXRaptor
TXRaptor
My bump stop extensions and air control valve arrived today. :cool:
My bump stops are at 115 psi. Does anyone have a psi setting to use when towing with the 3" extensions?
I called RPG, but there was no answer. They may be out for the holiday week.
