Rigid lights installed !!!!
TO 8217
TO 8217
Tulsa, OK
looks good, how does the 40" bar work with the front camera? thanks
I lost about 40% in the lower screen but it does not really bother me. The only time i would use it is when pulling in the garage but i have a spot on the wall i use for that. The guy at SPVparts.com told me they are currently working on a relocation bracket for the camera which i will buy when it is complete. It’s my understanding that they will move it to the upper part of the grille.
sixshooter_45
Arnold
A - Pillars is D series Pro’s
RDS 40” midnight edition pro
Lower pocket light:
D series Pro :
outside driving
Middle S.A.E.
Inside midnight edition spot
You will also notice I had all my brackets powder coated a dark flat bronze.
Looks great, are those the ZRoadz Two 3 in. LED Light Cube Hood Hinge Mounting Brackets?
If they are they're the ones that I have but not installed yet.
Did you have to use a longer bolt assuming they're the same ones? I ask because the metal bracket is really thick.
Thanks!
