Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Lighting Modifications Forum [GEN 1]
Rigid Industries DOT fog lights/spot lights install/review
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Raptor Embroidery" data-source="post: 847934" data-attributes="member: 5177"><p>Little update, the new F150 headlight switch is already shot. The ground pins inside the switch must have gotten stuck together. After a closer look, I found that rigid had a 60 amp relay attached to the harness. Dumb me didn't look at it before using it and it sent too much amperage to the switch. So to turn the fog lights off I had to disconnect the relay under the hood. </p><p>Keep in mind, they sent a 60 amp relay for cubes that draw 1.1 amps each.</p></blockquote><p></p>
[QUOTE="Raptor Embroidery, post: 847934, member: 5177"] Little update, the new F150 headlight switch is already shot. The ground pins inside the switch must have gotten stuck together. After a closer look, I found that rigid had a 60 amp relay attached to the harness. Dumb me didn't look at it before using it and it sent too much amperage to the switch. So to turn the fog lights off I had to disconnect the relay under the hood. Keep in mind, they sent a 60 amp relay for cubes that draw 1.1 amps each. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
Dudebrodude
Grumpy Banjo
taquitos
Rob O
Spike Spiegel
Gumby
Fyrman702
Steve737
wcm23
Mind Goblin
kevanscpa
scmustang
dsiggi
Stonehide
2011reptar
Hotsauz
viper2pt0
HaasMonst3r
badm0t0rfinger
Muchmore
Robertcrav
wyomingraptor
MotorsportsAustin
Andrewalker7
FreightTerrain
Gator85
Sharpie69
mashtastic
GoodJob_Daddy
Big Blue
Naks
Beard
JBeasonUSMC
isis
Johan
snt505
tlrmade
Frogger22
RdR2027
relak
IdahoPotato
sofakingloud
elninojimenez
CROOKS
Badboy4fun_wa
StuartR
kylesatx
thatJeepguy
Gael
25sheltergreenR
... and 32 more.
96,604
60,581
masoncullen12
Forums
Accept
Learn more…
