Hi all. I just got a 30” Adapt light bar that will mount to my SVC Baja frame cut bumper and was wondering if there is a way to tie it in to aux lights and high beams like others have done with other lights that don’t have their own controllers.
My understanding is that the controller will automatically go to the last mode that was activated.
What I would like to be able to do is have the RGB backlighting set to amber for daytime aux lighting and run the light with its speed sensor on High Beams. If running through the switches is needed that’s fine or if need to purchase some other type of larger switch module that work with high beams that is fine too. I’d almost rather use a piggy back type of module that will allow higher amperage across all the switches anyway.
Bests
Alex
Bests
Alex
