Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Review: Fold A Cover G4 Elite
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="TruckGuy616" data-source="post: 286094" data-attributes="member: 8500"><p>Hey BigJ, I'm a representative from Fold-a-Cover and came across your review. Just wanted to say thanks for the awesome write-up on our tonneau cover! We really appreciate it, and are very happy to hear you are enjoying your G4 Elite Cover!</p><p></p><p>Glad you got the rear blade seal to stick down properly. Most often they don't adhere well for two reasons...either it was too cold when applied so the glue didn't activate, or not enough pressure was applied to it after attaching it. Either way, glad you were able to get it back on and attached! On that note, you were right, the design is made so that you should close the tailgate, then close the cover to make sure you don't pinch the seal.</p><p></p><p><strong>As a "thank you" we'd be happy to send you some new end caps for your cover to make it look like new again! PM me your address and we'll get a pair out to you right away <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> </strong></p><p></p><p>I spoke with someone in manufacturing about why they may have fallen off, and our guess is that with the off roading, the body/bed flex is pushing that end panel into the caps, and over time the the screw loosened and eventually came out. His suggestion (depending on what you have in the bed at the time) is to simply fold up the cover behind the cab and snap it in place with the 3 straps when you are off road. That should help prevent it from happening again!</p></blockquote><p></p>
[QUOTE="TruckGuy616, post: 286094, member: 8500"] Hey BigJ, I'm a representative from Fold-a-Cover and came across your review. Just wanted to say thanks for the awesome write-up on our tonneau cover! We really appreciate it, and are very happy to hear you are enjoying your G4 Elite Cover! Glad you got the rear blade seal to stick down properly. Most often they don't adhere well for two reasons...either it was too cold when applied so the glue didn't activate, or not enough pressure was applied to it after attaching it. Either way, glad you were able to get it back on and attached! On that note, you were right, the design is made so that you should close the tailgate, then close the cover to make sure you don't pinch the seal. [B]As a "thank you" we'd be happy to send you some new end caps for your cover to make it look like new again! PM me your address and we'll get a pair out to you right away :) [/B] I spoke with someone in manufacturing about why they may have fallen off, and our guess is that with the off roading, the body/bed flex is pushing that end panel into the caps, and over time the the screw loosened and eventually came out. His suggestion (depending on what you have in the bed at the time) is to simply fold up the cover behind the cab and snap it in place with the 3 straps when you are off road. That should help prevent it from happening again! [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
LS1POWERED
GordoJay
Dudebrodude
FivePointO
pat247
SirSpeedyZ
tobias08
raptormv
jk47
clandrum
samwelll
TomDirt
WhoBeDankeyKang
GEN3LV
IMFletcher
JohnyPython
Dirtsmith
ToadSmasher2K1
Starboy786
FishFreak
Thamac15
Sozzy12
Craptor2
raptordawg1
dsg2003mach1
P4SHOCAT
IHAVETWO
Essam Riad
tabvette
snt505
SonoranGen3
murdok5
Relentles0ne
JohnnyJake
OffroadAlliance.com
Shedrack
Bubbasuwannee
raptor_qatar
kylesatx
tractorpole
Roscoe S
DMDRaptor
DNKS
Pyro3601
jdbakerucf
taquitos
wyomingraptor
djmoore710
moog5050
MurderedOutSVT
... and 8 more.
96,857
60,809
hazardsyd
Forums
Accept
Learn more…
