Tyler Bosworth
Gen 2 Raptor SCREW 145k
From time to time I will use the FORScan app to reset the transmission tables when trans starts shifting weird. There are 3 options in tcm section
1. Adaption tables
2. Reset all adaptations
3. Reset tcm control module
I usually reset all 3. Does anyone know if the order matters?
Also - should I be resetting anything on the ECM side also when I do this? I had the TSB done when it was in warranty but this reset seems to do the job. Wish I could have that valve body replaced again.
Forgot to include that after a reset I do the factory ford relearn procedures
Thanks for any info
1. Adaption tables
Thanks for any info
