Recall
wowanothertruck
United States
Anyone get a recall letter recently addressing loose underbody insulators? How long did it take to fix? Are dealers able to even fix the issue yet?
AxelR
Sunset
There’s a few threads already about this.
Yes they can fix it. It’s really quick for most, sometimes takes days to source the rivets.
Syberspace
Pittsburgh
Ive read some older posts but I wanted to get an idea of turn around time as of March 2022.
Depends on if the dealer has the parts and if your trucks insulation has damaged the driveshaft. If only rivets and they have them, should be a few hours. If it needs a driveshaft, could be weeks or more. Need to take it in to have the inspection and assessment.
Broken Wrench
Canton GA
Yup, took mine I. And it was done in a day. You can look under your truck to see if anything is loose or there is a groove or scoring on your driveshaft. If there is it will take a while for them to get a new driveshaft all they do is replace the plastic plugs with metal rivits.
