greatone99
Rear camera guidelines not Turning when wheel turns backing up , any ideas ??
Is there a way to disable it in the settings? I've never seen that option.enabled in the settings?
I know I've done it before, but what is the procedure to reset sync? Does it have any drawbacks (losing custom settings/changes you've made, etc)?reset sync all is fixed
You hold down the Power and arrow right (skip to next track) until the Sync will reset... There are no negative effects in doing this, I used to do that occasionally because my radio was getting stuck on Sirius XM station with no sound. I did not have to do that lately, maybe the latest Sync upgrade fixed it (?).Is there a way to disable it in the settings? I've never seen that option.
I have the latest SYNC3 v3.4.21098 and I also have that same issue every so often with no sound on any Sirius XM stations. SO it's not fixed.You hold down the Power and arrow right (skip to next track) until the Sync will reset... There are no negative effects in doing this, I used to do that occasionally because my radio was getting stuck on Sirius XM station with no sound. I did not have to do that lately, maybe the latest Sync upgrade fixed it (?).
