Rear Brake Rotors on Gen 3
hpschrank
Florida
2 questions I hope someone can assist me with:(Gen 3 with 37 PP)
1. Are the rear brakes/rotors considered “heavy duty”. I see when shopping for these they ask if it’s medium or heavy duty?
2. What size is OEM rear rotor in mm?
Thanks!
SurfRaptor
Newport Beach CA
You could pull a wheel and take the measurements with calipers and a tape measure, or a phone call to parts house at the dealer to get a part number. Once you have a part number, you can do a search and figure out the size from there. I would recommend both as a way of double-checking. Please update the thread, so we all have a part number.
Looks like 350mm and 336mm possibly. If you do buy, when you pull the rotor, match them up and check from there also before you install.
Coastal
Some Ford parts sites will take to the right ones / part numbers based on your VIN
