GEN 2 Rail systems
kdub405
So I have been looking at ways to incorporate a forward rail system for dirt bike tie down points, mainly a center tie down point. In my current setup, I purchased a Hi-Lift slide-n-lock tie down system and mounted to the front of the bed
This has worked perfect for my application however, I am not sure how the aluminum bed will hold up to this.
Any thoughts or other ideas on this?
SterlingE55
Houston
That load is spread out pretty well. I bet it holds up just fine. Just make sure you bolt it down using all the holes provided.
