Question: offset and wheels
BldredRaptor
Lafayette, Louisiana
Was thinking of getting these wheels for my race red 2020 raptor . The size is 20x10 with a -12 offset. Not sure about tire . I wanted a 35, but can I put this setup without lifting up the front? And what if I went with a 33 tire instead? May consider eibach springs but was trying to figure if I could get away with the 35 tire without them. Thanks for you guys opinions in advance
Raptor911
Ashburn, VA
You will rub with a 10" wide wheel at -12 offset at stock height. You will def need a lift of some sort.
And running a 33" inch tire to improve clearance would not look good.
Raptor911
Ashburn, VA
You could start with Eibachs and run collars to get additional height.
In general I would stay away from 10" wide wheels and - offsets. -12 is alot. You would do some damage if you off road your truck.
