Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Wheels & Tires Forum [GEN 1]
Question about Toyo M/T 315/70/R18...
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Bigg50" data-source="post: 507288" data-attributes="member: 9376"><p>I recommend you get them with a 0mm offset. This will help prevent rubbing. You can also flatten the pinch weld under the fender which will prevent the damage ihavegas has seen. </p><p></p><p>I ran 36" bfg mt's on mid perch and I was rubbing. I was able to take car of most of it by doing major trimming of the inner fender well and pounding in the corner. However, I still would hit the upper fender flare and actually shifted them up. The passenger side went into the a pillar and actually caused a small crack in the fender. </p><p></p><p>I would recommend not running 36's unless your on top perch which opens a whole other set of problems on the 2012's and up because of the torsion diff.</p><p></p><p>I'm about to try and stuff 37's on my new 13 with 0mm offset methods but I plan on doing major trimming to the fender lip. Plus I now have icons 3.0's which keep the suspension from bottoming out. It may not work for me but I'm willing to gamble. If you're willing to gamble than go for it.</p></blockquote><p></p>
[QUOTE="Bigg50, post: 507288, member: 9376"] I recommend you get them with a 0mm offset. This will help prevent rubbing. You can also flatten the pinch weld under the fender which will prevent the damage ihavegas has seen. I ran 36" bfg mt's on mid perch and I was rubbing. I was able to take car of most of it by doing major trimming of the inner fender well and pounding in the corner. However, I still would hit the upper fender flare and actually shifted them up. The passenger side went into the a pillar and actually caused a small crack in the fender. I would recommend not running 36's unless your on top perch which opens a whole other set of problems on the 2012's and up because of the torsion diff. I'm about to try and stuff 37's on my new 13 with 0mm offset methods but I plan on doing major trimming to the fender lip. Plus I now have icons 3.0's which keep the suspension from bottoming out. It may not work for me but I'm willing to gamble. If you're willing to gamble than go for it. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
mdamon
thatJeepguy
Oxford Raptor
swu011
ajm2332
steem430
WKUSMC
patwusmc
omalley72
BLJ
cavemanwelder
RAPTOR9one6
roger7254
supa-clean
Brapp_rap
TYRCS
Sierra117
itr111
Rednose
MC817
Turning Blue
Ox3721
hyrepower
HookEm
taquitos
The Car Stereo Company
Kjmor
2012SCSVT
icecoldak
Super_Raptorrific
thevanillagorilla
downforce137
3Dog
tractorpole
96,845
60,798
Douglasj76
Forums
Accept
Learn more…
