OK, Procharger doesn't have that number on their website
and that number (PMFS1A-001_I_10+R...) doesn't show results for me on Google.
@Tristan Shepersky
OK,
I found the instructions of that belt pattern you have pictured on the phone.
On Procharger's website it's for the 2007-2009 Expedition.
Page 10 in the installation instructions:
I see what's going on, you have the HO (non-Stage II) and that's the shared 6 rib belt system.
The Stage II Procharger is the second kit they made for the Raptor and that has a dedicated 8 rib belt system for the Procharger.
Stupid for Procharger not putting both install instructions on the website.
So, I apologize for confusing things.
And I still think you don't need to remove the Procharger unit to replace the belt.
Looks like you need to loosen the four mounting bolts for the Procharger bracket
and then you only need to remove the one bolt and Counter Bore Tube Spacer to get the belt around everything.
Note: "You may have to" loosen the bolts all the way so you can slip the spacer off the Boss.
You're going to have use a 1/2 break bar to pull or push the OEM tensioner down to allow the belt to slip over on to the last pulley you choose and at the same time with the Procharger tensioner.
I would pick the Procharger pulley for the last one if I was doing it.
Suggestion: This is a good time to replace the belt Tensioner, I get almost three years out of it before I start having belts shred
