I need to put my order in and I'm stuck between two models.
Can I get some votes on which one you guys prefer:
1: Stealth R:
2: Venom R:
Flush comparo:
1. Stealth R: (without winch)
2. Venom R (with upper lamp and winch)
1. Stealth R: Has a protected light bar with the metal bar above it. It has room behind the ADD logo for a small hidden light bar (with associated light loss) and for the two spots on the side. If I purchased this one I would get the hidden light bar and spots in amber in a fog light pattern and the main light bar as a long distance spot. This bumper appears to give a slightly better approach angle than the other one, but it also protrudes out a lot further.
2. Venom R: This bumper doesn't allow for side facing spot lamps. I would use the lower bar in a sweeping flood light pattern and the upper as a long distance spot. It's very nice but it might actually be overkill with insane amount of lumens going out. The upper bar isn't as well protected and may have a slightly worse approach angle than the other. The biggest upside of this one is that it is a lot more flush to the bumper. The biggest downside is that the upper lamp seems a bit like an afterthought.
So which one?
Thanks
1: Stealth R:
2: Venom R:
Flush comparo:
So which one?
Thanks
