Passenger Power Outlet
RaptorGhost
Miami, FL
So I was on a roadtrip with my wife and she connected her laptops charger in the passenger side outlet and it blew the fuse.
I’ve been searching the forums and can’t find what fuse it is in the hood fuse box. Any help would be greatly appreciated.
Donmatteo
Santa Clarita / Coronado
You sure it was the fuse? Sometime you can just power cycle the truck if there was too much of a voltage draw. It will cut off power if there is too much draw.
Power cycle it and see if the amber light comes back on.
RaptorGhost
RaptorGhost
Miami, FL
I’ve tried. It just blinks once and turns off and doesn’t turn back on again.
brucebarson
miami
Did you ever find the problem? I’m having the same exact issue with the 110 outlet by the passenger seat. Same model, same year. Can’t fine the fuse even with the fuse box diagram.
brucebarson
miami
Did you ever find a solution? I have the same exact issue
