I have a 2017 that threw this code. I cleared it and the CEL turned off, but I still see the code in permanent and pending. I read that permanent will disappear automatically if the internal emmission monitors past. But I guess since it's also in pending I have some issue.
I checked the lines that go to the PVC valve simply by looking at them and nothing obvious jumps out. I took off PVC valve at idle, hooked back up to hose and it had suction.
On the driver side, I confirmed dipstick firm in place. Oil cap on tight.
These are all simple things to check after googling the code on the internet. I don't have any other symptoms besides the code. Seems to run great. A tiny bit rough at idle, but I don't think it's excessive. I also noticed mouse droppings on engine cover so I looked at the 2-3 vacuum hoses I could see that were obvious as well as wire connectors. They look fine.
I do have an ESP and I need to get the brake, tailgate and door lock recalls done so I'll probably take it in, but I need an inspection so wouldn't mind figuring it out on my oown either.
Any ideas??
Any ideas??
