A little over a year ago we set out to develop a lower control arm for the SVT Raptor that would not only enhance the drive, but offer far more versatility than the factory Lower Control Arms, plus other aftermarket Lower Control Arms currently on the market. The arms themselves are full box construction, the inner chasis pivets are a robust 1.5" spherical bearing with an equally large 1.5" bearing on the knuckle side. The arm is welded both inside-and-out to insure a guaranteed sturdy arm that will hold up to almost anything you can throw at it. However, it wasn't enough for us to to stop there. This arm is developled to accept a stock shock, an aftermarket 3.0" shock or our SVT Raptor industry first, stock width dual Fox Racing Shox 3.0" bypass setup for unmatched control.
During this past year of testing we learned a great deal about the geometry that was needed for optimum ride performance plus small, but neccesary things like incorporating steering stops into the arm to limit the wear and tear on the factory steering box, thus also minimizing damage to the lower control arm itself. The arm will bolt right up using grade 8 hardware, top of the line center-pins plus 12 point nuts all wrapped in a beautiful titanium powder coat to last for the long haul.
However, the best and most versatile part of the arm is found sitting on the back side. When bolting up Raptor Performance Group Lower Control Arm, you will now be able to run our Dual Fox Racing Shox 3.0" By-Pass setup. The control is amazing and the damping power is light years beyond any single 3.0" setup that will ultimately take you into terrain that was otherwise unthinkable. With our new Lower Control Arm and Dual shock setup, jumps that use to leave you cringing are now nothing more than mellow launching pads keeping you urning for more.
$1595.00 for the pair:
Fox 3.0" External Front Bypass $1999.00
Pricing for the arm also includes the upper bypass shock mount for Dual 3.0" setup.
Thanks for all your patience everyone.
Almost done with the our webpage, but I wanted to get this up for now so you guys can finally see the official pricing.
