Off-road and recovery
The Car Stereo Company
here, on frf
my bed is packed. big socket and wrench toolbox. 10 gallons of gas. hydraulic jack. 4 air compressors. 10 gallons of onboard air. 30ft 30,000lb tow strap. 3/4" shackles. 30ft 120,000lb kinetic rope. 2 soft shackles, knock off maxtracks, valve stem remover, impact driver. basically anything i can think of to repair or pull someone out at our events. no winch though. too heavy and not worth it for me to have since i probably have needed one once in the 7 years i have had my truck. even then, the tow straps worked just fine. you ned to figure out where and how you drive to determine what you need to keep in the truck with you. dont go based on what others tell you unless you are going together often and both need the same gear.
