No 4WD in my 2014 Raptor, the driver side vacuum actuator is not engaging
Kamaro
Hi guys,
I discovered that the 4wd is not working at all in my 2014 Raptor, I tried to left both front tires while engine is on and 4wd in hi, by turning the passenger tire I can see that it rotates the axle with it, but the driver side is not, so I knew the vacuum actuator is not engaging. Whats the best way to diagnose the culprit? Where can I find a vacuum diagram to trace the possible vacuum leak?? searching google didn't help me at all, only for the older models.
Steelhead
Hi guys,
I had the same problem. local shop did a vacuum test and all was fine. I ended up replacing the solenoid and resolved the issue.
