New voltmeter gauge
ZBoater
I'm going to install a voltmeter gauge. Is any switched power source good enough or is there a specific spot I need to connect this gauge to?
ZBoater
ZBoater
Sorry, don't know what pkp means. I even Googled it and came up with Polish Railways. Don't think that's it. ;)
The Car Stereo Company
here, on frf
its the pkp
---------- Post added at 08:21 AM ---------- Previous post was at 08:18 AM ----------
ok, i will stop messing with you. the pkp is passenger kick panel. its at the bcm in the big plug in the top with the wires exiting up. a blue wire about 14 ga
Ruger
Northern Nevada
I did it on my old Nissan D21. Any 12 source will do as long as it's not hot until the key is turned. A volt meter tells you three things:
- When you turn the key to the accessory stop with the engine not yet running, it'll give you battery voltage.
- When you're starting the truck it'll give you an indication of the draw from the starter. Look quick.
- When the engine is running it'll give you alternator output.
Volt meters are way more useful than ammeters.
I'm curious, Z. How/where are you going to mount the gauge?
ZBoater
ZBoater
I PMed SDHQJason to check the price of the steering column single pod. That's Plan A. If it's too much in the way, I'll wait until the A Pillar mounts are ready from them, which should be any day now.
I saw it mounted in place of the 12V outlet on the dash, but my Nexus 7 is covering that spot. Plan C is the Roush air vent solution.
ZBoater
ZBoater
Here it is, but I'm replacing it with another gauge with red marks. This one is blue and just looks out of place.
Members online
95,897
59,594
AnotherBasicRaptor
