Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
New Raptor Owner
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Poodles84" data-source="post: 1229497" data-attributes="member: 24150"><p>So I freaked out about this same decision. I bought all the parts before my truck arrived and loved it so much when i picked it up, i got scared to change it!</p><p></p><p>But i pulled the trigger anyway.... </p><p></p><p>I just finished my truck with SVC CAS, Deaver +3s (1" taller ish) and BFG 37s (also did the camburg UCAs). It's definitely taller. I didn't take any measurements but level i'd say about 3-4" in front and 2" in back. </p><p></p><p>The ride with the CAS cranked up on stock springs is about 20% stiffer than stock. SVC did all the work and they are fantastic. Very responsive to my ridiculous questions, did amazing work; my truck is dialed. </p><p></p><p>For me this was a great starting point to see if I liked the setup and wanted to stay on 37s. I've got about 500 miles on it like this would recommend. If you like it you can always change to Geiser springs down the road or swap to the Fox or King setup. </p><p></p><p>If you are staying on 35s and don't carry a butt load of stuff, stay with the +2 rear (stock ride height) or run the +3s with SDHQ or RPG drop shackles.</p></blockquote><p></p>
[QUOTE="Poodles84, post: 1229497, member: 24150"] So I freaked out about this same decision. I bought all the parts before my truck arrived and loved it so much when i picked it up, i got scared to change it! But i pulled the trigger anyway.... I just finished my truck with SVC CAS, Deaver +3s (1" taller ish) and BFG 37s (also did the camburg UCAs). It's definitely taller. I didn't take any measurements but level i'd say about 3-4" in front and 2" in back. The ride with the CAS cranked up on stock springs is about 20% stiffer than stock. SVC did all the work and they are fantastic. Very responsive to my ridiculous questions, did amazing work; my truck is dialed. For me this was a great starting point to see if I liked the setup and wanted to stay on 37s. I've got about 500 miles on it like this would recommend. If you like it you can always change to Geiser springs down the road or swap to the Fox or King setup. If you are staying on 35s and don't carry a butt load of stuff, stay with the +2 rear (stock ride height) or run the +3s with SDHQ or RPG drop shackles. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
TheInfamousDrew
YoshiTheRaptor
patwusmc
Rednose
stevelp99
daniel805
ajm2332
BLJ
96,845
60,799
daniel805
Forums
New Raptor Owner
Accept
Learn more…
