We are introducing our new in bed tire carriers. They are bolted in using the front 4 bed bolts so no drilling is required. There are 2 different versions available. High mount and under cover. The high mount allows for space under the tire to be used for jack storage and other things. The tire is mounted just low enough that you cant see it in the rear view mirror. The under cover mount fits under bed covers and jack mounts can be mounted on the sides. The tires are held down with t bar and it holds up to a 37. Stock wheels will need to be mounted upside down but will work.
Material Used--
1.50 .095 wall DOM
Tig Welded
Pricing--
Raised mount- 399
Raised mount with Jack Mount and Skid- 649
Uses Harbor Freight 2 ton jack, lockable
Under Cover Mount- 379
All pricing is raw metal. Powdercoating available in any color.
Email us or call the Shop to order.
Material Used--
1.50 .095 wall DOM
Tig Welded
Pricing--
Raised mount- 399
