GEN 1 Need Tune Emergency Truck Down
Mikee Martin
SVC. Krazy House Customz. JDM. Seaside Superbikes
California
The truck is a 2017 Gen 2 Raptor..I posted in Gen 1 by accident..Thank You for your advice, I am grateful to have some help...I have a custom tune and like an idiot I tried to reprogram the tune to temporarily remove a problem the active transmission developes over time. I updated the SCT firmware and then re loaded the tune. When the tuner smiled at me and said have fun, reverse was going in and out. Non driveable. Need a tune E mailed to me using my truck and tune box info. Please call me, ill pay any way you want. Thank You.
Mike Martin 831 760 2701 [email protected].
As I opened this forum I saw the following quote from another thread, it tells a bit more of the story..
"You would need to have your tuner build the file using the latest Ford PCM/TCM calibration. Otherwise as soon as you tune it the updated calibration will be overwritten."
Its even worse..LOL..You are absolutely correct..I want to go to Pismo Beach this weekend, so im late night auto shop..Wanted a quick fix, (reprogram and erase all computers memories, trans works for 6 months..) so I decided to reprogram. Unfortunately, I forgot that if I update to the latest version firmware, my tune, which made me delete all others due to CUSTOM TUNE..will make my custom tune corrupt. Well, when the SCT box completed programming and updating, reverse goes in and out while backing up, undriveable..need a tune Email tomorrow bad..Anyone who can help, I will pay for a tune Emailed, I will give all ECU information, vin, address, $$$..Thanks!!!
Mikee Martin
Mikee Martin
California
Load the stock tune and attempt tune reload.
Thank you for the advice. I have attempted loading the stock tune. It still doesn't like reverse. I saw a log in the Software that says something about an incomplete firmware upload, but I can't figure out how to do over. It thinks the latest version is installed and makes me jump right to uploading the Tune..Everything but 7th to 8th gear shifts was ok until I uploaded the newest firmware on the SVT device. Ive tried everything I can hooked up to the Truck, and the laptop, minus the part that says only for Derive (sct software) use..hard overide or wipe clean, 2 different options in the Derive software..
Thank You!
Monday I will try SCT tech support or get a new box next day air..
